Тема: Дорога на Грозовые Ворота
Думаю завтра с семьей прокатиться, посмотреть Грозовые Ворота.  Подскажите как дорога? На стоковом ШЕВИКе вариант проехать? Если ехать по данному треку http://tracks.skif4x4.ru/file_download/ … hdenie.plt ни каких "засад" нету?
Re: Дорога на Грозовые Ворота
Так будет понятнее. Ранее здесь писали про дорогу.
[map]44.60964,38.22157 44.6106,38.22212 44.61101,38.22229 44.61142,38.22267 44.6121,38.22273 44.61259,38.22291 44.61338,38.22282 44.61374,38.22326 44.61365,38.22376 44.61379,38.22464 44.61378,38.22705 44.6137,38.22775 44.61338,38.22909 44.61297,38.23019 44.61241,38.23109 44.61185,38.23186 44.61128,38.23282 44.61092,38.23357 44.61043,38.23451 44.61031,38.23499 44.61069,38.23694 44.61099,38.23833 44.61131,38.2392 44.61117,38.24028 44.61087,38.24168 44.61033,38.24276 44.60957,38.2435 44.60921,38.24412 44.60919,38.24548 44.60909,38.24616 44.60844,38.24712 44.60803,38.24769 44.60718,38.24778 44.60621,38.24763 44.60573,38.24743 44.60444,38.24686 44.60289,38.24594 44.60242,38.24578 44.60133,38.24548 44.60083,38.24519 44.59993,38.24497 44.59914,38.24508 44.5984,38.24484 44.59698,38.24421 44.59577,38.24362 44.59572,38.24329 44.59547,38.24331 44.59421,38.24388 44.59276,38.24463 44.59216,38.2452 44.592,38.24627 44.59196,38.24706 44.59161,38.24788 44.59123,38.2488 44.59112,38.24904 44.5911,38.25027 44.59089,38.25123 44.59049,38.25296 44.58988,38.25378 44.58943,38.25441 44.58868,38.25456 44.58787,38.25472 44.58744,38.25492 44.58701,38.25533 44.5867,38.2552 44.5867,38.25467 44.58711,38.25404 44.58762,38.25277 44.58756,38.2522 44.58711,38.25136 44.58622,38.24989 44.58561,38.24915 44.58514,38.24884 44.58455,38.24884 44.58363,38.24866 44.58304,38.24849 44.58237,38.24801 44.58209,38.24759 44.58175,38.24735 44.58119,38.24726 44.57996,38.24816 44.57928,38.24882 44.57889,38.24976 44.57863,38.25053 44.57799,38.25103 44.57716,38.2511 44.57641,38.25117 44.57619,38.25165 44.57614,38.25189 44.57594,38.25235 44.57535,38.25277 44.5749,38.25277 44.57375,38.25206 44.57312,38.25154 44.57281,38.25127 44.57242,38.25145 44.57215,38.252 44.57181,38.25239 44.57141,38.2525 44.57006,38.25182 44.56909,38.25112 44.56826,38.25046 44.56764,38.24989 44.56695,38.24871 44.56666,38.24849 44.56584,38.24816 44.56544,38.24849 44.56526,38.24884 44.56481,38.24873 44.56402,38.24893 44.56286,38.2493 44.56217,38.24917 44.56175,38.24873 44.5614,38.24834 44.56067,38.24783 44.55982,38.24777 44.55918,38.24755 44.5583,38.24632 44.55758,38.24542 44.55713,38.24439 44.55689,38.24419 44.55512,38.24355 44.5547,38.24309 44.55398,38.24246 44.55351,38.24206 44.5529,38.24178 44.5526,38.24147 44.55168,38.24099 44.55118,38.24083 44.55094,38.24042 44.55094,38.23983 44.55068,38.23934 44.54994,38.2391 44.54908,38.23884 44.54866,38.23814 44.54834,38.2375 44.54793,38.23717 44.54705,38.23679 44.54633,38.23605 44.54582,38.23508 44.54536,38.23394 44.545,38.23326 44.54475,38.23293[/map]
TLK 105 пишет:
Искал, но поиск результатов не дал... default/sad
три недели назад Мазда тройка при мне поднималась по этой дороге, не знаю с потерями или нет доехала, но любой полноприводный авто эту дорогу даже не заметит
Патрол Y60-Черныш! длинный, rd28t(пока), лифт +2Tough Dog и джанглы 34"
89181635430(Андрей)
Назар пишет:
Спуститься то мазда спустится, а вот подняться на пару подъёмов, имхо, осилит только на учкуре.
Полный привод=легко.
Назар пишет:
Понял. Спасибо!!!
Нормально там всё, я на волге ездил, но глушак оторвал.
в июле были на грозовых там стоял солярис.
Спасибо всем. Значит завтра стартуем... Мясо закуплено,ребенок уже игрушки приготовил.
Toly23 пишет:
Эээ... как бы там пожарники блюдят за этим.
TLC 105, ну не обязательно же на грозовых шашлык жарить, чуть дальше проехал, залез куда повыше https://i.mycdn.me/image?t=3&bid=834836514913&id=834836514913&plc=WEB&tkn=*c6wTVYSzu1ncUeYrvWLqGcJlsxA и с красивым видом, например вот так https://i.mycdn.me/image?t=3&bid=834836514657&id=834836514657&plc=WEB&tkn=*PTos3eX0lA9nfl0HmKRjhmJteNw пожарил мясо, полюбовались закатом!
Отредактировано Vist (26.08.2016 15:23:26)
8-909-45-36-889 Виталий.
Toly23 пишет:
В теме Поездка Выходного Дня (ПВД) страница 1093, сообщение 27316, ZEN все подробно описал. default/good3
Отредактировано Виталий 353 (26.08.2016 16:16:15)
8-918-93-52-32-два
TLC 105 пишет:
Toly23 пишет:
Да, точно...Забыл,  по новостям говорили... default/blush2
Vist пишет:
Да, думаю по пути будут места, где можно тормознуться. Мангал разборной, так чтонормально.
Виталий 353 пишет:
Toly23 пишет:
Спасибо, прочитал, расписано очень подробно. А поиск не выдал ни чего... default/sad
Нормальное место для шашлыкинга если проехать немного назад по хребту в сторону Тхаба, немного не доезжая до спуска со шлагбаумом.
Тихушник пишет:
Спасибо,понял...
Toly23 пишет:
Тихушник пишет:
Спасибо,понял...
Куча мест в сторону Адербиевки с потрясающими видими как на морскую сторону п.Дивноморское , так и вид на г.Папай, г.Шизе...абинский район...
Съездили. Дорога отличная, на встречу попалась пузотерка.... 174 регион. Мясо пожарили, нашли место. Первый раз, зато впечатлений куча, у всей семьи.
Друзья, подскажите не закрыт ли шлагбаум, при повороте в Возрождении? Хочу на выходных сгонять, кто был недавно как дорога?
Отредактировано andrew79 (10.05.2018 17:12:25)
andrew79 пишет:
Были пару недель назад- было открыто
Теперь- шоколадный Патриот  , 33е Cooper, а так полный сток)
8-967-301-ноль99ноль
andrew79 пишет:
На майские праздники был открыт...
А в чем проблема проехать когда он закрыт? default/neutral  Мужику в будке посигналил, он вышел, что-то записал и поднял шлагбаум...
Lelik80,
Lelik80 пишет:
andrew79 пишет:
Спасибо
andrew79 пишет:
Проезжали там 2 мая на въезде был трос натянут (с трассы видели)
Да. Я делаю много ошибок. Жизнь, к сожалению, без инструкций. 8-903-45-000-37
Серега Борода пишет:
andrew79 пишет:
А другие въезды есть?
MMC L200 32" MT + Лебёдка
Был там на выходных, трос натянут . Меня записали в книгу где я росписался за костры и мусор и меня пропустили. Вечером было все открыто.
KoT_KRR пишет:
Есть , с противоположных торон.
